funny fenders and reading a plug....
Old Jan 7, 2001 | 10:43 PM
waynaferd's Avatar
I don't know why I'm puttin this part in, but today I hooked up the hot water hose to get rid of all the snow and ice packed in and around my quad, and I rinced the fenders all off. I was watching, and as the hot(not hot hot, just hot) water hit the fenders, the ends curled down about an inch(and no, I wasn't drunk....if I was I'd still be out there watching). I thought that was pretty wierd. Musta been stiff from the cold. Anywho, I'm about to put on a clamp-on K&N w/o airbox and an HPD pipe. Can anyone tell me what to look for on the plug to verify the correct jetting? Should it be a specific color? Oh, and what should I expect outa this combo, anything THAT amazing? I still haven't decided on which springs for the clutch, and I'm kinda thinkin' the orange one from HPD. I have a 00 TBlazer, and thanks for any help......
Old Jan 7, 2001 | 10:48 PM
NewDSLover's Avatar
Plug should be brown, not white nor black. Ride up a small grade for 20sec or so(half throtttle) and kill the power and stop. Pull plug and check color(as above). Pipe will add 6 or so hp. This was a big deal on my Scrambler 400 2x4.
Old Jan 7, 2001 | 10:51 PM
NewDSLover's Avatar
forgot on thing, stock jet in my scram was a 220 main. After K&N, Pipe and Vforce Delta upgrade, it went up to a 270. Start off rich on your main and work your way down. Better rich than lean. Good luck.
Old Jan 7, 2001 | 11:23 PM
will's Avatar
if you are gonna spend the 200.00 and some odd dolars on the pipe you might as well buy the clutch kit. Your pipe will be a waste of money until you do.
Old Jan 7, 2001 | 11:38 PM
waynaferd's Avatar
Thanks,NEWDSLOVER for the help. I got the pipe for X-mas, had the filter, and can't decide which springs and wieghts, because I plan on going down 2 teeth on the rear sprocket. Oh, and I meant a pink primary, not orange..
Old Jan 8, 2001 | 01:21 PM
BLH's Avatar
BLH
Check out this guys tech page…. It has an explanation of sparkplug reading complete with very good pictures of the different plugs.
http://charm.air.on.ca/cbjaps/ATVZone/
ultangler
Nov 30, 2024 01:35 AM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
