add oil?
Old Nov 19, 2007 | 10:56 PM
shorse's Avatar
Default add oil?
i just watched the polaris DVD that came with the quad. i'm confused on two things..
do i have to add oil after every tank of gas like on my snowmobiles / chainsaws...
do i have a fuel shut-off valve and reserve tank on the 500HO EFI?
thanks! erick
Old Nov 19, 2007 | 10:58 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default add oil?
if its a four stroke(which it sounds like it is) no you just check the oil every so often to make sure its up and there is no shut off for the gas or reserve on an efi model.
Old Nov 19, 2007 | 11:18 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default add oil?
Ever since Polaris had the new LED fuel guage(bar graph).......No reserve......With this feature I do believe!!!.........Am I Correct???..........Caper.
Old Nov 20, 2007 | 08:27 AM
shorse's Avatar
Default add oil?
thank you
Old Nov 20, 2007 | 12:48 PM
sheepdogMSP8117's Avatar
Default add oil?
I thought my 500 had reserve......I'll have to check it. As far as adding oil, I've never had to add any between oil changes. Unless you're burning it or have a leak somewhere, you shouldn't have to add any.
