hawkeye engine removal
Old Dec 12, 2007 | 07:08 PM
coolhandnts's Avatar
Default hawkeye engine removal
if any body can give me a basic removal instuctions on how to remove the engine it would be greatly apprieciated i have a 300 four wheel drive 2006 hawkeye.
thank you toby
Old Dec 12, 2007 | 08:29 PM
onesavage's Avatar
story,pics,,why the heck so soon!!!
Old Dec 12, 2007 | 08:49 PM
well there's beer and deep water involved it runs fine untill it reach's temp then a nice tapping checked it out with a stethoscope and found the noise was coming from the bottom end or so i think until i tear it down slowly I.E. first the head then so on. when i hit the i did not hit fast but when the water reached the rack's i turned it off the next day i drianed everything and started it and heard the noise after 6 to 7 min of runing it .
Old Dec 12, 2007 | 09:41 PM
onesavage's Avatar
..was it a " hold on to my beer and watch this"moment!!
Old Dec 12, 2007 | 10:29 PM
Hell yea!!!!!!!!!@
Old Dec 13, 2007 | 12:26 PM
onesavage's Avatar
been there,done that!! ended up in a 12ft deep pond with my sporty floating up-side down hydro locked!! after draining aout 10 gallons of water out of every orfice and changeing all the fluids and the oil and filter about 8 times still runs great,,guess i got luckey..did i happen to mention i live in michigan and i found the only pond in febuary that WAS NOT FROZE.. i learned a lesson,let the jack a$$ that came up with the idea GO FIRST!!!
Old Dec 13, 2007 | 07:15 PM
well it sure sucked the next day after the hangover wore off
Old Dec 13, 2007 | 07:23 PM
onesavage's Avatar
heck it sucked getting my quad out of a 12 ft pond when it was about 32 degrees out... i still went home and drained all the fluids.. i was sicker then a dog for a week and a half..
Old Dec 14, 2007 | 07:08 PM
yea im glade i live in florida sometimes it really suck's now i've got tear it down to the bare bone's . i ordered a service manuel it should be here monday or the following day then the work start's
Old Dec 15, 2007 | 01:53 AM
UTU's Avatar
UTU
I would drain all the fluids and try again> Takes a while to get all the water out> 2-3 times at least!!!! we always use diesel fuel and oil run a bit and drain.... we some times just use diesel fuel till motor get warm and drain. Takes a while to get the water/moisture out.....
