overheating
Old Dec 18, 2007 | 09:28 AM
marmon's Avatar
Default overheating
I have a 01 sportsman 500ho that overheated during our last snowstorm i plowed for 4-5 hours and anti-freeze spewed out of the resevoir. My hi-temp light never came on so i figured it was hot and the cap is old so it purged through. Anyways i fired it up yesterday and within 10 minutes it started spewing anti-freeze again?, with no Hi-Temp light on again? I'm getting a new cap today, but is there anything else it could be? After i shut it down i left the ignition on and the fan only ran maybe 5 -10 seconds? I figured that if the pump failed i should still get the hi-temp light, as its in the head? Anybody else have any ideas?
Old Dec 18, 2007 | 10:13 AM
RolliePollieOllie's Avatar
Default overheating
Your hi temp indicator could be screwed. Check to make sure your rad isn't plugged or restricted by snow.
Old Dec 18, 2007 | 08:10 PM
ohnet's Avatar
Default overheating
On my 1995, the coolant kept coming out the resevoir and I realized the bike's coolant wasn't hot. I was getting air bubbles because I had a compression leak. In my case it was the head gasket. I went and rebuilt the whole top end. Don't know if that helps you, but that is my story.
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
