2002 Sportsman 500
Old Dec 21, 2007 | 10:18 AM
mcobrien's Avatar
Default 2002 Sportsman 500
I have a 2002 Sportsman 500 with a Moose plow and a MileMarker winch. I have been plowing snow of late with it and after about 45 minutes it runs a bit rough and shuts off. If I try to start it up nothing happens, it just turns over. If I wait about 20 minutes it will start right up and run fine. I have tried dry gas already thinking I had some water in the gas. Does anyone have an idea what might be causing this?
Thanks
Mike
Old Dec 23, 2007 | 04:44 PM
trail hog's Avatar
Hey Mike,
I have the same problem with my '98 500 sportsman. I found that I have no spark to the plug and I put in a request for help myself. Sorry I can't be of more help.
Good luck, Don
Old Dec 23, 2007 | 05:01 PM
wilsonoo's Avatar
have you changed the fuel filter lately, and or could the carb. be freezing up, it does sound like fuel problem.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 23, 2007 | 09:32 PM
DODGEARCHER's Avatar
almost sounds like your fuel vent is clogged, and not letting the carb get any fuel. Like pouring gas out of a can with no vent it will only let so much out with no vent. Check your lines from the tank, and good luck
Old Dec 23, 2007 | 09:33 PM
Trail hog. Did you check you kill switch to see if it was on. How about the battery terminals, are they clean and tight. Will the quad start with the pull start?
Old Dec 23, 2007 | 09:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check to see if its spark when you try to start it right back up. if so then it might be a blocked vent line. take the gas cap off to see if theres any pressure release. if so thats the problem.
Old Dec 23, 2007 | 11:22 PM
trail hog's Avatar
The kill switch is in the on position. I have a brand new battey and everything is clean and tight. The motor turns over with no problem, just have no spark to the plug.
Old Dec 24, 2007 | 12:48 AM
Kerbbirds's Avatar
it's probably vapor locking, the gas is getting burned before it gets to the motor, try taking that heat tape around all the gas lines, did it to both my machines, and they no longer do that
Old Dec 24, 2007 | 01:05 AM
sprinter10's Avatar
i am havint the same problem with my 500 scrambler and i have the 500 sportsman engine in it
i did the fuel cap thing
i drained the tank
i changed the fuel filter
i cleaned the carb checked teh adjustment
and i still cant figure it out
Old Dec 24, 2007 | 11:51 AM
94harley's Avatar
This is a log shot but there were some 500's around that year that had a piched spark plug wire and it would do very strange things to the motor. They would run, they wouldn't run, miss, etc. From the factory they were pinched between the fuel tank and the frame. It would still test good usually with an ohmmeter but wouldn't work. Check it and if it's pinched, get some new plug wire(bulk) from the parts store(napa, etc.) and replace it.
