sp 500
Old Dec 24, 2007 | 12:31 PM
jaymazurk's Avatar
Default sp 500
Hay guys...its been a while since I needed to post anything but I am having a issue with my 97 sportsman 500. She will start right up initally and after about 3-5 minutes of warming up it will die out of the blue. I go to start it back up and it wont start no matter how many times I crank it. Let it sit for say ahour or so come back and again it will start running 3-5 min later.....dead....I checked the air intake all clear. I havent looked at anything else yet hoping somebody might be able to point me in the right direction before I start tearing into the thing. Maybe next I will check the plug for fouling??.....any ideas would be greatly appreciated
Old Dec 24, 2007 | 12:37 PM
02magnum500's Avatar
Gets his share of deer.
Default sp 500
I would say mabey pull the carb and clean the jets, the pilot always gets clogged the fastest. Also. mabey check the ETC for proper throttle play....1/8" or so. Does it run good if you are on the throttle with it?
Old Dec 24, 2007 | 01:08 PM
jaymazurk's Avatar
Default sp 500
yeah when it does run....its as if nothing is wrong......I can even run it around the yard a bit.......then it just quits....as if it runs out of gas!!
Old Dec 24, 2007 | 01:19 PM
Default sp 500
check throttle free play for the ETC first...if that is in spec then go to the pilot jet..
Old Dec 24, 2007 | 02:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default sp 500
just an idear but when it stalls out open the gas cap to see if it has pressure when you take it off. if so the vent lines might be plugged. check the ones on the handle bars as well. just a thought.
Old Dec 24, 2007 | 09:43 PM
RickCJ7's Avatar
Default sp 500
When it shuts off check for fuel or spark and go from there!
Old Dec 28, 2007 | 09:24 AM
jaymazurk's Avatar
Default sp 500
Ok I pulled the spark plug that is brand new and it is defiently getting gas..plug is wet...however when I checked for spark I am only getting it every once in awhile? The wire isnt pinched and looks to be ok and like I said it will spark but rarely??? IS this stator related?
Old Dec 28, 2007 | 09:27 AM
RickCJ7's Avatar
Default sp 500
<div class="FTQUOTE"><begin quote>Originally posted by: jaymazurk
Ok I pulled the spark plug that is brand new and it is defiently getting gas..plug is wet...however when I checked for spark I am only getting it every once in awhile? The wire isnt pinched and looks to be ok and like I said it will spark but rarely??? IS this stator related?</end quote></div>
Could be bad plug, stator, coil, safety control on throttle check the easy stuff 1st!
Try new plug and adjust throttle 1st.
Old Dec 28, 2007 | 11:11 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default sp 500
What Polaris models/makes had the spark plug wire pinched??................Caper...............Worth a check!!
