Blown Trail Boss 250?
Old Dec 24, 2007 | 07:13 PM
juttin_15's Avatar
Default Blown Trail Boss 250?
My polaris died like it was getting to much fuel, then it sorta locked up but when i turned the engine backwards it would turn forwards for a little then lock up. I think it has to do with my new exhaust. Is the cranshaft bearing bad or the piston cracked? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 24, 2007 | 07:45 PM
ftwflh's Avatar
Bet you broke a piston.Never hop up an old engine without first doing a topend
Old Dec 24, 2007 | 07:48 PM
juttin_15's Avatar
thats what i thought, will a topend out of a 300 trail boss work?
Old Dec 24, 2007 | 08:15 PM
ftwflh's Avatar
No it wont work without some major modding.You can rebuild the topend for less than $200 as long as you didnt get parts in the lower end.If you have to split the cases be sure to use new crank seals.
I have a 93 250 Trailboss too that is a decent little machine.But it is staying stock
Old Dec 24, 2007 | 10:28 PM
juttin_15's Avatar
I have a 1994 trail boss 300, can i pull the engine and exhaust off will it work on my 250?
Old Dec 24, 2007 | 10:31 PM
juttin_15's Avatar
what would you sugest to do next for a 300ex that has a 400ex piston.
Old Dec 25, 2007 | 10:01 AM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: juttin_15
what would you sugest to do next for a 300ex that has a 400ex piston.</end quote></div>
Dont know what you mean
But I dont mess with Hondas
Old Dec 25, 2007 | 06:47 PM
tbsleeper's Avatar
trailboss 300 and trailblazer are not compatible. Ones a 2 stroke and ones a 4stroke...correct?
Old Dec 25, 2007 | 07:28 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tbsleeper
trailboss 300 and trailblazer are not compatible. Ones a 2 stroke and ones a 4stroke...correct?</end quote></div>
300 is a 2stroke but cylinders wont interchange with a 250
Old Dec 25, 2007 | 08:37 PM
juttin_15's Avatar
i will buy a new topend, any sugestions
