06 sportsman pulls hard to right
Old Dec 30, 2007 | 05:00 PM
oinkjackson's Avatar
Default 06 sportsman pulls hard to right
after i loaned out my spare sportsman.(2 wks ago) i took it for 1st ride since i loaned it out and it pulls to the right really hard. my 1st thought was check tire pressure. all the tires had even pressure.. i looked underneath and didnt see anything bent...any suggestions please?.......thx in advance.
Old Dec 30, 2007 | 05:10 PM
SCRAMMYTODD's Avatar
Does it do it in 2wd and 4wd or just 4wd?? If it does it in 2wd I would suggest something in the suspension bent, or a brake locking up. If it only does it in 4wd look at the other things as well as make sure you don't have a broken CV or an axle.
Old Dec 30, 2007 | 08:57 PM
trail hog's Avatar
Sometimes they get stuck in 4wd even when you shift into 2wd. Try backing up about ten feet in 2wd. Go forward and see if it still pulls. Might work
Old Dec 30, 2007 | 09:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its not in awd doing it make sure the bearings arent bad as well.
Old Dec 30, 2007 | 09:38 PM
RnR's Avatar
RnR
Did you check the toe alignment? On mine the book says 1/8" to 1/4" toe out.
Old Dec 31, 2007 | 11:29 AM
thx for all the input guys...im gonna check it out today.......thanks!
MikeyBoyesq
Nov 27, 2020 02:44 PM
coldnorthpol
Jul 14, 2015 11:22 PM
toonces
Jun 30, 2015 11:19 AM
bonanza 440
Jun 26, 2015 10:01 PM
Fullblast
May 26, 2015 12:38 AM
