Where is the oil filter on 2003 predator 500
Old Jan 3, 2008 | 09:15 PM
PismoPredator500's Avatar
Default Where is the oil filter on 2003 predator 500
hello, i just recently bought a 2003 pred 500. I dont want to spend the 200+ for someone else to change the fluids. But for the life of me i cant find the oil filter and i dont have the manual. SOMEONE HELP!!
Thanks!!
Old Jan 4, 2008 | 12:30 PM
Evasiveone's Avatar
It is on the right bottom side of the engine right in front of the rear brake pedal held on by 3 bolts. If you go to a Polaris dealer and buy the oil change kit it has the filter, 2 qts of oil, new o-rings and new drain plug with step by step instructions and torque specs. After that you can just buy the oil and filter and keep the o-rings and drain plug in case the original ones go bad.
If you go here. Polaris web page and look under the riders tab, it has a place where you can download a manual for your quad.
Edit: It is not the cover where the radiator hose goes into, but behind it towards the brake pedal
Old Jan 4, 2008 | 12:43 PM
scootergptx's Avatar
Supersock
Hired Gun!
Go to this website and go down to the Polaris section. You should be able to download the service manual for free.
Old Jan 4, 2008 | 06:42 PM
Hey thanks alot for the tips i was looking at the kit, looks like a good idea. I found the manual on the polaris site too.
Thanks ALOT!!
PP500
Hw00d
Sep 10, 2015 08:53 AM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
chewy78
Sep 8, 2015 10:37 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
