2005 Sportsman 800 EFI idle problem
Old Jan 6, 2008 | 01:14 AM
brother_gary's Avatar
Default 2005 Sportsman 800 EFI idle problem
I have a 2005 Sportsman 800 EFI that will not ilde. I took it to a dealer and they told me that I needed the engine rebuilt. So I let them. It idle OK for one trip out but the idle problem retuned. The dealer has not been any help. Has anyone had an idle problem with a Polaris 800 EFI and was able to find the problem?
Old Jan 6, 2008 | 08:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
explain more about why the delaer rebuilt the engine because of an idle issue. there is no idle adjustment beside the dealer doing it w/ the computer. you have the etc adjustment in the cable and thats it. what does it do or not do? how much did they rebuild?
Old Jan 6, 2008 | 12:57 PM
JCDEYO25's Avatar
Just to add one thing to Sten's, If your running a K&N air filter and have been riding in dusty conditions, grime will buildup in the throttle body and will wreak havoc with your idle as it did mine.....If you're running a K&N post back and I'll walk ya thru what I did to fix the problem...
John
Old Jan 7, 2008 | 07:02 AM
metro's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
there is no idle adjustment beside the dealer doing it w/ the computer. you have the etc adjustment in the cable and thats it. </end quote></div>
That's where you are wrong. Idle can be adjusted from a D-shaped screw in throttlebody with suitable pliers or a home made tool. There is no need for computers. If you want to intialize or check the base setting of the tps, all you need is 2 pieces of wire, accurate volt-meter and that tool with what you adjust the throttle plate.
Old Jan 7, 2008 | 07:16 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i havent tried to adjust the throttle idle as i was told you cant so why doent you walk thru the complete procedure on how to do it so everyone will know and can try it.
Old Jan 8, 2008 | 12:31 AM
Yes I am running a K&N air filter. In fact the dealer told me I needed to spray more oil on the filter than I was doing because he saw dust in the throttle body.
This is why the dealer believe I sucked dirt into the engine causing a compression leak and a rebuild. I beleived I got screwed. So yes, please tell me what you did to fix the problem.
Gary
Old Jan 8, 2008 | 12:43 AM
JCDEYO25's Avatar
Ok this is pretty simple.......Just remove the rubber boot which goes to the throttle body.....You're gonna get some throttle body intake cleaner, I used 3M, open the butterfly in the TB, you'll probably see some grime in there, spray some cleaner in there but not too much.....Then take a Q tip and clean the walls of the TB and the butterfly itself......Take your time and do a thorough job..Then put everything back together.....Well that's all I did and my idle returned to right around 1150rpms...Good luck and let me know if it works for you...BTW were you driving in any dusty conditions cause thats what did mine in.......
John
Old Jan 8, 2008 | 12:47 AM
I was told by the dealer that the idle problem was caused by sucking dirt into the engine causing ring and valve problems. All because he believes I did not use enough oil on my K&N filter. They replaced both pistons, rings and valves. The fix was short lived.
Old Jan 8, 2008 | 12:51 AM
JCDEYO25's Avatar
So are you having the problem again then??????Are you running a filter skin?
John
Old Jan 8, 2008 | 11:12 AM
sheepdogMSP8117's Avatar
Looks like the procedure is a pain in the butt, but if you're having problems then I suppose you'd have to try something.
THIS thread explains how to do it.
