1995 xplorer 400 dies in reverse
Old Jan 18, 2008 | 02:27 PM
97SOLOMA's Avatar
Default 1995 xplorer 400 dies in reverse
Anyone know why this happens, happens time to time, unless i hold the override button than all is fine. Engine completely dies, any thoughts?
thanks in advance
Old Jan 18, 2008 | 02:37 PM
94harley's Avatar
The Reverse limiter box is probably bad. Unhook the black wire and it will stop doing that. It will also haul a$$ in reverse so be carefull.
Old Jan 18, 2008 | 03:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its fine when the button is pushed, then the limiter switch is bad like harley said.
Old Jan 18, 2008 | 03:20 PM
97SOLOMA's Avatar
can you point to where it is [img]i/expressions/face-icon-small-smile.gif[/img] thanks for all your help, finally getting rid of these old girls since a new 800 is in the garage [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 18, 2008 | 04:10 PM
97SOLOMA's Avatar
i looked in the handle bar controls and the gear selector wires and none of them are black, is it somewhere else or possibly a different color?
thanks again
Old Jan 18, 2008 | 04:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it should be mounted to the tranny.
Old Jan 18, 2008 | 06:03 PM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
it should be mounted to the tranny.</end quote></div>
It's not on the tranny. Take the front rack and cover off. There is a regualator and the other is the limiter. The limiter should have a black, green, yellow and white wire(if memory serves) Remove the black wire, tape it up so it ccan't ground out and put it back together.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
