Spark Plug for High Compression
Old Jan 24, 2008 | 02:17 PM
no694terry's Avatar
Default Spark Plug for High Compression
Got the motor back from RCR and looks all good and stuff. Put it back together with the 488 sled piston he let me choose. I have always ran a NGK B8ES, now I read some where that a hotter plug is a good idea when running higher compression. The heads been shaved and Im not sure if the sled piston will effect compression but rick told me I should be around 140 psi when all together. Im not even sure if thats high compression but its better than 110psi.
Its a 250r/es Scrambler Air cooled .020 over wesico
Runnin 93 Octane with Klotz Techni-plate oil 32:1
Stock Coil and CDI, DG Exhaust
Old Jan 24, 2008 | 02:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats not real high compression, more close to brand new. running w/ shaved heads will change it for sure. what did rick tell you to run? dropping 1 plug number could be alot hotter then you want so i would ask him(the expert) for sure before you do it. are you running the 93 octang because of the shaved heads?
Old Jan 24, 2008 | 02:35 PM
no694terry's Avatar
I run 93 because I have always run 93, I guess cause its when I get gas i put it in a gas can after I fill up my car, My car requires 93 and since the pumps already set then the can/bike gets 93 too.
Old Jan 24, 2008 | 05:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
in most cases the higher octang is wasted in regual engines. unless your running at 10 to 1 compression. w/ the plane heads and hotter plug you would be running hotter heat for sure i would think. maybe rick should be telling you what is best here, or someone w/ race engine savoy.
Old Jan 24, 2008 | 07:00 PM
nekkidbik's Avatar
When you raise the compression you need to run a COLDER plug. You definitely don't want to run too hot a plug with an air cooled 2 stroke.
Old Jan 24, 2008 | 11:25 PM
jimmypsp700's Avatar
Mine is at 12:1 and HPD and RCR recommend 92 min octane.
My machanic said to try the BR9es plug.
I'm running the NGK Iridium BR 8 EIX , it makes a difference (in fouling).
Jim
Sjrpp
Jun 2, 2019 07:25 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
MNatv89
Jul 7, 2015 11:36 AM
D-Hagz
Jul 4, 2015 02:19 AM
