pipe discs
Old Mar 20, 2008 | 07:54 AM
ftwflh's Avatar
Default pipe discs
If you dont run at leeast the recomended number you stand a chance of burning valves
Old Mar 20, 2008 | 12:04 PM
polarisman600's Avatar
Default pipe discs
thanks for the info guys.
Old Mar 20, 2008 | 12:31 PM
sheepdogMSP8117's Avatar
Default pipe discs
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
If you dont run at leeast the recomended number you stand a chance of burning valves</end quote></div>
I thought there was a risk of burning the exhaust valve is you ran too many discs without rejetting.
Running fewer than the recommended minimum shouldn't hurt the engine, but will hamper performance. If the exhaust system is too restrictive, the engine will not be able to breathe, or exhale properly I should say, and power will top out very early in the rev range.
I added a Benz ATV Silencer to my 800 and while it made it nice and quiet, it added so much back pressure that it didn't want to go over 25-30 mph.
Not an expert on this, but I have "experimented" a lot. So this is JMO. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 20, 2008 | 05:22 PM
WAATV's Avatar
Default pipe discs
I have one on my 2004 SP700 carb and started it with whatever number came on it (can't remember now). It was too loud for my ears, so I took it down to 4-5 disks. That quieted it down and it now feels like a good balance between power and sound level.
Performance-wise, the muffler made a small difference. A much bigger difference came from my DynoJet kit - now THAT made a HUGE difference in behavior (at least at the low end - takeoff is almost scary now).
I haven't had the chance to take it out and run it at mid and high throttle yet, so I may find that the new jetting causes the muffler disk count to be adjusted again.
Old Mar 20, 2008 | 10:08 PM
  #15
ftwflh's Avatar
Default pipe discs
<div class="FTQUOTE"><begin quote>Originally posted by: sheepdogMSP8117
Not an expert on this, but I have "experimented" a lot. So this is JMO. [img][/img]</end quote></div>
By incressing the back preasure you will burn a valve due to heat build up in the combustion chamber.he jetting issue will burn a valve too but from buenning too hot
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
