PLOW SETUP
Old Mar 26, 2008 | 10:30 PM
jimpet's Avatar
Default PLOW SETUP
Good stuff a lot to chew on. I hear that Swisher is a very good plow and they have a variety of attachments. I never heard of Cycle Country so I do not know if they have attachments for various utility needs.
Old Mar 26, 2008 | 10:36 PM
sprinter10's Avatar
Default PLOW SETUP
http://www.cyclecountry.com/ they hace a few stuff. alot of accesories for the plows from markers to plastic wear blades to plow stuff like paving stones. brooms for the atv. look at the catolog
<a target=_blank class=ftalternatingbarlinklarge href="http://www.cyclecountry.com/manuals/Catalog/pgs%201-8.pdf
">http://www.cyclecountry.com/ma...g/pgs%201-8.pdf
</a>
<a target=_blank class=ftalternatingbarlinklarge href="http://www.cyclecountry.com/manuals/Catalog/pgs%2009-16.pdf
">http://www.cyclecountry.com/ma...pgs%2009-16.pdf
</a>
<a target=_blank class=ftalternatingbarlinklarge href="http://www.cyclecountry.com/manuals/Catalog/pgs%2017-24.pdf
">http://www.cyclecountry.com/ma...pgs%2017-24.pdf
</a>
http://www.cyclecountry.com/ma...atalog/pgs%2025-32.pdf
Old Mar 27, 2008 | 09:20 AM
jimpet's Avatar
Default PLOW SETUP
This is very helpful
TAHNKS
Old Mar 27, 2008 | 01:07 PM
mtpockets's Avatar
Default PLOW SETUP
<div class="FTQUOTE"><begin quote>Originally posted by: jimpet
Hi,
I am in the market for a plow setup for my son's 1997 sportsman 500. I am having trouble trying to figure out exactly what I need to level my gravel drive way and plow snow in the future. I would need a complete setup as it does not have a winch or anything else. I read that Swisher was the way to go because it has many attachment options. I really do not have much money to invest in it so I would be happy to find something used but I do not even know what I need.
Thanks,
Jim</end quote></div>
You will be monumentally dissapointed if you buy the Polaris Glacier2 plow. Although the hook-up/disconect couldn't be easier, the mounting plate is a flimsy piece of junk. I moderately pushed snow into a snowbank and after a few passes, I looked under the ATV and the plate bowed downward and upfront the bolts were pressing against the radiator. Polaris obviously never tested this product and has failed miserably!
I had to buy a new mounting plate and had a local welder re-inforce it. It has not snowed since so I have not had a chance to see if the "fix" works.
Others have made good suggestions on what to buy. Cycle Country, Warn, Swisher.
Old Mar 27, 2008 | 01:37 PM
  #15
jimpet's Avatar
Default PLOW SETUP
Yeah I am leaning toward Swisher because it accepts other attachments but I have not ruled out Cycle Country
Old Mar 27, 2008 | 02:56 PM
  #16
mtpockets's Avatar
Default PLOW SETUP
Yeah I am leaning toward Swisher because it accepts other attachments but I have not ruled out Cycle Country</end quote></div>
I forgot to mention Moose Utilities plows. VERY heavy duty, VERY reliable.
Mooseutilities.com I think.
Old Mar 27, 2008 | 10:17 PM
  #17
sprinter10's Avatar
Default PLOW SETUP
cycle county has attatchments 2 what type of attatchments are you looking for?
Old Mar 27, 2008 | 11:06 PM
  #18
jimpet's Avatar
Default PLOW SETUP
loader bucket, fork lift...
Old Mar 27, 2008 | 11:31 PM
  #19
sprinter10's Avatar
Default PLOW SETUP
look at this one i know someone who had this type of set up read the thing about the mount it mounts on your rear trailor hitch and a arms. it has forks buckets and plows for that mount http://www.northerntool.com/we...70_200150824_200150824 they even have a rear suspention lockout to keep it stiff while pulling plows and stuff like a tracktor. http://www.northerntool.com/we...70_200333205_200333205 the pallet lifter is $129 the mount is $160 the plows are $170 to $270 the bucket is $400
so for mount $160
60 inch standard plow $220
palled lifter $130
bucket $400
it woud be around $910
it looks like is a preety strong set up. anyone ever try this set up? polaris made a set up similar to this me neigor had itworked good bolted on teh trailor hitch.
Old Mar 28, 2008 | 12:41 AM
  #20
jokout's Avatar
Default PLOW SETUP
MT, interesting that you would suggest the Moose utility plows since the Glacier II and the Moose Rapid mount are the same plow!
