Please help
Old Apr 22, 2008 | 10:05 PM
jareddigby's Avatar
Default Please help
Well the new carb is in my 94 sportsman 400 & changed the spark plug won't start it fires & trys to start.
Old Apr 22, 2008 | 10:21 PM
dogspower1's Avatar
Default Please help
was it running with the old carb sounds like its not get fuel float could be hung up not let fuel to the carb check the simple thing like gas in it is the fuel turned on
Old Apr 22, 2008 | 10:25 PM
jareddigby's Avatar
Default Please help
<div class="FTQUOTE"><begin quote>Originally posted by: dogspower1
was it running with the old carb sounds like its not get fuel float could be hung up not let fuel to the carb check the simple thing like gas in it is the fuel turned on</end quote></div>
Old carb broke
Old Apr 22, 2008 | 10:34 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Please help
Take the plug out after trying to start(turning over) ...............And see if it is wet or dry.......This should tell you .............air or fuel trouble!!.......Caper.............
Old Apr 23, 2008 | 12:19 AM
slinky-1979's Avatar
Default Please help
have u checked the timing
