Worse case?
Old May 13, 2008 | 12:12 AM
TxMagnum's Avatar
Default Worse case?
When turning the rig sideways on the trailer the front right tire got stuck. It moved further outside than it normally does I guess what I'm trying to say it the wheels were no longer parallel and I think I heard a pop. I cant find anything wrong and the wheel went back into place without much effort. I wonder if the front bearing is screwed up? I rode it pretty fast afterward to see if the wheel would fall off and it didnt.
Old May 13, 2008 | 01:31 AM
Kerbbirds's Avatar
Default Worse case?
jack it up and try to move it from side to side, make sure all lug nuts are tight, check your tie rod ends, because there was a recall on the 425 magnums tie rod ends. not sure if you got it done or not. and then you can check your wheel bearings
Old May 13, 2008 | 07:20 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Worse case?
while its jacked up check the tie rod ends good for any play like he said. you dont want it popping off at any speeds or it will be real bad. i dont know if theres a stop on the steering post or not but maybe give that a look see to see if that broke or popped over the stop. just a thought.
Old May 13, 2008 | 11:58 AM
jodaanja's Avatar
Default Worse case?
<div class="FTQUOTE"><begin quote>Originally posted by: TxMagnum
I rode it pretty fast afterward to see if the wheel would fall off and it didnt.</end quote></div>
Hmmm.......I'm not sure that test procedure is completely safe :-)
Old May 13, 2008 | 03:22 PM
firehog's Avatar
Default Worse case?
Whaddya mean....That's the true test procedure! LOL!
Old May 13, 2008 | 06:46 PM
sprinter10's Avatar
Default Worse case?
yea im not shure if I would do that to test but everyone has different ways they do things lol
Old May 13, 2008 | 07:08 PM
jokout's Avatar
Default Worse case?
well, if it is broken there is no missing it with that proceedure! LOL!
Old May 13, 2008 | 07:17 PM
sprinter10's Avatar
Default Worse case?
good point you will definitely know in a short amount of time haha.
Old May 14, 2008 | 03:34 AM
user493's Avatar
Moto Psycho
Default Worse case?
It's okay. I used to be crash test dummy too. [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 14, 2008 | 02:05 PM
TxMagnum's Avatar
Default Worse case?
<div class="FTQUOTE"><begin quote>Originally posted by: firehog
Whaddya mean....That's the true test procedure! LOL!</end quote></div>
Thats how firefighters do it. Straight to the point sink or swim, "lets roll". You know what I mean dontcha Hog?
EIF
Apr 20, 2017 07:15 PM
Pgbama11
Jan 16, 2016 08:19 AM
WilliamBos
Sep 22, 2015 04:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
