running out of gas
Old May 28, 2008 | 02:51 AM
jp1's Avatar
jp1
Default running out of gas
I would like to know if anyone with a 2004.5 700 efi sp. is haveing the same problem. You can ride for about 2 hr's and then it will die . It act's like it runs out of gas. let it set about an hr' and it will start and run just fine. for awhile then it will do it agin. didn't have a very good weekend. let me tell ya them 700's are heavy when they are upsidedown on top of you. now my holiday weekend off of work got extended by a couple of day's, doctors orders
Old May 28, 2008 | 10:44 AM
jodaanja's Avatar
Ouch! I hope you are ok. Sounds like you could have a clogged tank vent??
Old May 28, 2008 | 11:02 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Yes....Open the gas cap next time it does this and see/hear if there is the sound of air being released..................Caper...............
Old May 28, 2008 | 11:04 AM
Did you check for oil in the airbox after the Quad was turned over?
Don't know how long ago this happened but did the oil level drop also?
Glad your not hurt too bad...............Caper...........
Old May 28, 2008 | 11:59 AM
sheepdogMSP8117's Avatar
Yes, sounds like you're okay of you only need a couple days off work. Glad to hear that. No broken bones at least.
Definitely sounds like a tank venting problem. Or if not that, maybe the fuel pump is getting hot and shutting down until it cools off. My 800 has never shut down on its own.
Old May 28, 2008 | 05:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
next time it shuts down listen for the fuel pump when you try to star it. but i see you made another post so maybe you already found out it was the pump.
Old May 28, 2008 | 07:36 PM
jp1's Avatar
jp1
well I dont know. but when it act's up the fuelpump sounds like it's not pump'en like it should. It dont always do it. the last time we rode. we rode hard for hours and no problem's . So im going to replace the pump & the E.T.C and see what happens.
Old May 28, 2008 | 09:47 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would want to make sure b4 you replace it. why would you want to replace the etc as its adjustable and it wouldnt be that.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
