Mayday(in june)
Old Jun 1, 2008 | 09:08 PM
TxMagnum's Avatar
Default Mayday(in june)
After successfully installing new boots on the front I decided to make sure the awd still worked. So I flipped the quad over climbing a hill. It really more like rolled over onto the right side then onto the seat. It ran for about 10 seconds then died as I flipped it back over. It ran briefly afterwards (badly) now it wont start at all. I have noticed the plug keeps getting fouled and the oil doesnt smell like gas. I have tinkered with it for a few hours now and cannot get it start. Any ideas, or am I going to have to bend over for a shop?
Old Jun 1, 2008 | 09:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like it flooded it self out. if the plug keeps getting wet turn off the gas and make sure the plug is good and dry. also did check the air box for gas or oil? hold the throttle wide open to clean out the cyclinder while your tring to start it. just an idear.
Old Jun 1, 2008 | 09:29 PM
TxMagnum's Avatar
thanks, the plug isnt wet though its carbon fouled, which is weird, like the choke is not adjusted. I did find some oil in the air box.
Old Jun 1, 2008 | 09:50 PM
user493's Avatar
Moto Psycho
If the air filter is wet get a new one. Whenever I rolled one of my quads over I just let it sit for awhile before I tried starting it. All the gas and oil has a chance to go back where it's supposed to be. They were flooded and started hard but ran good afterward. I guess I was lucky.
Old Jun 2, 2008 | 12:37 AM
Kerbbirds's Avatar
i'd pull the plug out and turn the gas off and crank the motor a few times, get the gas out of the cylinder, turn the gas back on, put a new plug in it and try to start it
Old Jun 2, 2008 | 12:38 AM
Kerbbirds's Avatar
so did ur 4wd work
Old Jun 4, 2008 | 10:43 PM
MagnumPO's Avatar
yeah it worked. I found out what the problem was. The flywheel key was sheared. my local dealer did not know what it was when I described it to him. I brought the old one in and even found a picture with it. I tell you if you are at all capable you are better off on your own. I mean every small engine I have ever seen has a key sometimes its called a woodruff key but its there. The thing cost 8 bucks and will be here in a week. ridiculous.
Old Jun 5, 2008 | 11:04 AM
user493's Avatar
Moto Psycho
I thought a woodruff key would be a lot cheaper, but the last one I bought was for a mower. I got a generic one from the hardware store.
Old Jun 5, 2008 | 12:54 PM
MagnumPO's Avatar
i made one for in the meantime it seems to work. any leads about your stolen rig?
Old Jun 5, 2008 | 01:19 PM
user493's Avatar
Moto Psycho
Gonedi. Gone like Gandhi. When it didn't show up the same day like last time, I figured it was gone for good. When the first two were stolen, the '97 was found totalled out but the '01 was never recovered. It figures they would keep the newest one. Now they have an even newer one. It didn't have 300 miles on it. By the time I got it back last year, summer was over. I rode it once, plowed snow 20 miles, and they stole it before summer started.
bvolks
Jun 13, 2015 08:14 AM
dorene
Jun 5, 2015 05:25 PM
tprender
Jan 22, 2001 11:02 PM
CHICKENman
Jun 10, 2000 12:18 AM
