Puking Gas
Old Jun 25, 2008 | 06:12 PM
ohnet's Avatar
Default Puking Gas
Especially right after I start up my 2 stroke Scrambler, I'm getting lots of gas out the vent tube. However, when I run it for awhile it calms down quite a bit. Is this normal and what do I adjust to lessen the leakage? Should it leak any at all? The tube is coming from the carb.
Old Jun 25, 2008 | 06:14 PM
Jayblazer's Avatar
Default Puking Gas
sounds like its time to replace the needle valve and seat in the carb that sould fix you up..
Old Jun 25, 2008 | 06:53 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Puking Gas
vent tubes from the tank or the carbs? make sure there not building pressure. imo.
Old Jun 25, 2008 | 10:54 PM
MagnumPO's Avatar
Default Puking Gas
Im pretty sure it is not supposed to leak copious amounts of explosive propellant. I think that the float may be sticking or like the other guy said the needle valve.
Old Jun 26, 2008 | 01:59 AM
CaptainQuint's Avatar
Default Puking Gas
Puking gas? Well, my gas has been known to make people puke....
Old Jun 26, 2008 | 03:57 AM
user493's Avatar
Moto Psycho
Default Puking Gas
<div class="FTQUOTE"><begin quote>Originally posted by: MagnumPO
Im pretty sure it is not supposed to leak copious amounts of explosive propellant.</end quote></div>
lol. Thanks for the laugh Magnum.
Old Jun 26, 2008 | 06:10 AM
wartdog's Avatar
Default Puking Gas
my trailboss did the same. checked the float level and that worked.
Old Jun 26, 2008 | 12:44 PM
Kerbbirds's Avatar
Default Puking Gas
Needle and seat under the float is bad , replace it then start turning the gas off when machine is parked and it will last a long time.
Old Jun 26, 2008 | 06:54 PM
ohnet's Avatar
Default Puking Gas
Ah Kerbirds, you caught me. I feel like my hand is in the cookie jar. I never turn the gas off. I never knew why they have those shut offs. OK, I will start doing that. Also, Stendori, it's not from the tank, but thanks for mentioning, it never hurts to check on that stuff.
Old Jun 26, 2008 | 09:24 PM
user493's Avatar
Moto Psycho
Default Puking Gas
I heard that transporting them without turning the gas off was BAD for it.
