2002 Scrambler 500
Old Jul 3, 2008 | 09:43 PM
SDI600's Avatar
Default 2002 Scrambler 500
Hi everyone I just purchased a 02 scrambler 500 and am looking to put larger mud lites on it. I am aware of the fact that the front tires are 1 inch bigger than the rear...how does this come into play when purchasing larger tires and what are my options as far as size goes. I was hoping to put 28's on the front and 27's on the back. Does anybody have any advise.
Old Jul 4, 2008 | 10:23 AM
ftwflh's Avatar
you wont have the gearing to pull that big of tires or the clearance
Old Jul 4, 2008 | 10:42 AM
SDI600's Avatar
ok thanks do you know what the biggest I could go is?
Old Jul 4, 2008 | 10:47 AM
ftwflh's Avatar
25 front 24 rear
Old Jul 4, 2008 | 02:23 PM
SDI600's Avatar
thanks again
Old Jul 4, 2008 | 08:09 PM
SDI600's Avatar
I was reading somewhere else that 27 front and 26 back is the biggest you can go clearence wise...would you not recomend that?
Old Jul 4, 2008 | 09:54 PM
700 sportsman's Avatar
probably not without clutch mods
Old Jul 9, 2008 | 02:22 AM
klemmer's Avatar
is it not possible or has anyone not been able to figure out the ratios between the front and rear drive on a scrambler so that you can put bigger tires on the back and gear accordingly so you don't have to put bigger tires on the front? could anyone tell me why this is not possible.
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
