2004 trailblazer eng spec help!
Old Jul 4, 2008 | 01:37 AM
kenmore1's Avatar
Default 2004 trailblazer eng spec help!
Hello, I have a 2004 trailblazer, 250 cc eng, that i have toasted a piston on. I have the jug off and piston in hand. Can anyone tell me what the spec is for the standard bore of this engine? It measures at approx 2.829. I need to order a piston and will go as large as i have to. Just don't know if it has ever been bored before and don't have a manual. Thanks in advance!!!
Old Jul 4, 2008 | 02:31 AM
RickRitter's Avatar
Stock bore --> 2.835"
20 over -------> 2.854"
Old Jul 4, 2008 | 07:21 PM
take your cylinder and piston to a dealer that bores cylinders (a lot sub out to machinists!) He should be able to tell you what oversize to bore that will clean out cylinder usually second over will clean up unless deeply grooved. After bore and hone,with piston in cylinder without rings, check clearance, should be no more than .0015-.002 with feeler gage. Ring end gap .008-012,can file ring ends if dealer doesnt. BREAK-IN slowly.
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
chewy78
Sep 8, 2015 10:37 AM
