You might be a Polaris rider if........
#61
... you're reading this.
... your ATV will comfortably fit riders over 6 feet tall, even if it's a budget-priced 250/330.
... your favorite forum has <u>people</u> named Trailblazer, Trailboss, Magnum, Scrambler, and Sportsman.
#62
you might be a polaris rider if you spent a lot of time at the Polaris dealer talking about the next trail ride they are putting on and what new quads they are bringing out for you to ride!
#63
If you have much more range than anyone else you ride with;
If you are able to go down a steep hill without applying your brakes; and
If you are able to either ride two up or instantly convert to a 400 lb. capacity cargo bed...
Then you might be a Polaris X2 500 (with ADC) rider.
#67
... if your 500 is nearly the same horsepower as a Honda 680.
... if you've ever heard of an "angry chainsaw".
... if you're waiting for someone else to post because you already have three more answers.
#69
... if your ATV squats a little with 600+ pounds on it.
... if you've ever gone "redneck skiing" behind an ATV... in the summer.
... if you look up at night, point out the North star, and tell people that's Polaris.
#70
I thought the key turning off was only my problem.
You might be a polaris rider if your dry storage rack becomes filled ith empty aluminum from all your buddys who don't have any place to put them.
<div class="FTQUOTE"><begin quote>Originally posted by: sheepdogMSP8117
If you don't have to push a button to start your ATV,
if you can't ride with a key ring attached to your ignition key because it will hit the gas cap and turn off when you crank the handlebars,
if you have plenty of built-in waterproof front rack storage, you might be a Polaris Rider.</end quote></div>
