86 Trailboss won't rev up
Old Aug 6, 2008 | 01:28 AM
alfire166's Avatar
Default 86 Trailboss won't rev up
I just cleaned up my 86 250 Trailboss that had been sitting for a couple years. It ran great when it was parked. I put an oil pump on it because it had been plugged and was using mixed gas. I cleaned the gas tank and carb and it fired right up and idles good. When you give it gas it throttles up good to about half throttle then it seems to bog down and won't run as fast as it should. Any ideas?
Old Aug 7, 2008 | 01:03 PM
coal dirt's Avatar
Hello,I am currently expieriencing a similar problem with my 86 trailboss,other members of this site have been generous with there ideas and sggestions which I am going to try today.Check out the thread "Can anyone help me get my polaris running" posted yesterday,perhaps some of the ideas given can help you!!!
Old Aug 7, 2008 | 01:14 PM
700 sportsman's Avatar
have you cleaned and adjusted the carb???
Old Aug 7, 2008 | 03:41 PM
sassee's Avatar
I'm not familiar with an 86 model. Does it have a Reverse Speed Limiter on it like later models? If it does, it should have a button on the left hand control that says "override" Press the button in and if it revs up, then you will have to make a shifter linkage adjustment (because it may think it is in reverse) or replace the limiter switch.
My 97 trail boss had the same symptoms. I pressed in the Override button and it revved fine. I had to adjust the shift linkage and it's ran fine ever since.
Old Aug 7, 2008 | 10:02 PM
alfire166's Avatar
I cleaned the carb and adjusted it as directed in my Haynes manual. It does have a reverse speed limiter and I will give that a try.
Old Aug 8, 2008 | 12:04 AM
user493's Avatar
Moto Psycho
Probably not the ETC making it do that, but just in case, make sure the throttle has 1/16" - 1/8" slack.
68_327_c20
Nov 25, 2023 12:26 PM
Magistar
Apr 13, 2023 04:39 AM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
2000Polaris
Sep 13, 2000 10:22 PM
