500 atp
Old Sep 10, 2008 | 05:09 PM
FAAMECH's Avatar
Default 500 atp
Got a friend that has 500ATP and not sure on changing oil and filter. What conerns him is the oil res. I have found that you must drain res and engine. When you re-service, do you put .5 qt in engine and 1.5 into res tank????????
Thanks,
Old Sep 10, 2008 | 06:14 PM
miniexcavator's Avatar
Default 500 atp
no, 2quarts in res., you must prime if you take the screen out of res. to clean
Old Sep 10, 2008 | 07:42 PM
FAAMECH's Avatar
Default 500 atp
Thanks. To prime is line just above the screen pinched during initial engine run up . I have read that He should look for a slit in the line?????????????? and pinch off there. How long do you have to have the line pinched????
Thanks
