How do i rejet a scrambler 500 4-stroke
The Question i have is do i need to take the carb off to rejet and where is the Jet even located. I put a new pipe on it and i am kinda retarded when it somes to these things but a guy told me i really should rejet it. PLEASE HELP ME cause i do not wanna pay someone to do it. Maybe a website or something where i could get step by step instructions.
thank you for your time
After carb pulled back from intake manifold, remove float bowl screws(soft,dont strip) MAIN JET big round jet with slot. MAY not have to rejet. Warm up,run at high speed,kill with emergency switch,LET COOL DOWN,remove plug,should be medium tan color on plug electrode. OR if plug whiteish color, hesitates or pops back through exhaust usually lean condition,THEN rejetting MAY be necessary. Also can raise carb needle to help compensate. Depends on type pipe installed. Other members can probably point you to websites or advise you. Good luck
I HAVE TO because of big hands and not much room on Scrambler. Plus have to pull air box out of the way and remove carb support.
exmotocrosser
Sep 13, 2019 06:12 AM
