problems with carb
Old Oct 19, 2008 | 05:13 PM
s7jstep1's Avatar
Default problems with carb
i have two problems with my carburetor that i need to address. 1. i have to turn off the fuel valve every time i shut the quad off or all of me fuel will slowly drip out of the carburetor. 2. the quad wont start without priming it with starter fluid. any ideas on how to fix these?
Old Oct 19, 2008 | 05:30 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like to me the float is either not set correctly or the need and seat is dirty or needs replacing as gas is leaking buy it. pull the plug out and see it ifs wet from gas.
Old Oct 19, 2008 | 05:42 PM
s7jstep1's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
sounds like to me the float is either not set correctly or the need and seat is dirty or needs replacing as gas is leaking buy it. pull the plug out and see it ifs wet from gas.</end quote></div>
what plug and how do i set the float?
Old Oct 19, 2008 | 05:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
spark plug. the float should be level when the carb is upside down.(carb should be off). how many miles on this bike and did you do a compression test. how does it run when its running. just a few ideas
Old Oct 19, 2008 | 07:27 PM
s7jstep1's Avatar
ok ill check the plug and carb settings. i have no idea on the mileage. its an 86 trailboss 250. id like to get a carburetor rebild kit eventually. when its running it sounds good. a little sluggish if i let it idle a while and then rev it but other than that its pretty good.
Old Oct 20, 2008 | 12:08 AM
TacticalRaptor's Avatar
sounds like your float is sticking. I just went through the exact same syptoms with my 00 magnum. take the carb off, flip it upside down and take off the bowl. you will see the plastic float, it should move freely. if not remove it and clean it up.
Old Oct 20, 2008 | 02:43 AM
s7jstep1's Avatar
i dont think its the float sticking because i have taken the carb apart 3 times and every time it still does it. tomorrow ill look at it and see if its just out of adjustment
Old Oct 20, 2008 | 07:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
how did the needle look when you had it apart. doesnt take alot of wear to make them leak fuel by.
Old Oct 26, 2008 | 03:04 PM
s7jstep1's Avatar
i noticed that when held upsidedown, the float was slightly upward. i pushed it down to level and now the quad will start without starter fluid. i still have the problem with having to turn the fuel valve off but i figure u can put up with it until i get a rebuild kit
Old Oct 26, 2008 | 07:40 PM
HARLEY_OWNER's Avatar
technically your supose to turn off your shut off... its bad on the floats or somthing.. dont ask me my step dad drilled that into me for years...
