Noise on 550 XP when shutting off -- maybe 850 too?
Old Oct 26, 2008 | 11:22 PM
cc-rider's Avatar
Default Noise on 550 XP when shutting off -- maybe 850 too?
When I turn the engine off on my 550 XP, there is some sort of noise that comes from the engine. It sounds like some sort clicking that almost resembles and electrical arc sound (though I am 90% sure that it isn't an arc). It is very faint and I didn't notice it until I shut the thing off when it was nice and quiet in my garage. The sound can be repeated by also turning the key on and then off, but not starting. It is perfectly consistent....same sound every time.
Anyone else heard this?
Old Oct 27, 2008 | 12:49 AM
eggenz7's Avatar
probably just a solenoid somewhere that is turning off. i believe there are solenoids in the rear end for the awd and turf mode selections not sure on that tho.
Old Oct 27, 2008 | 08:57 AM
sportsman rocks 's Avatar
Maybe fuel presser regulator releasing the fuel presser, my 2008 500 HO EFI does the same thing when turning the key off.
Old Oct 27, 2008 | 10:01 AM
snosnake's Avatar
Fuel pump pressurizing before you start it and releasing pressure when you stop...
Old Oct 27, 2008 | 11:24 AM
cc-rider's Avatar
That makes sense...thanks for the replies...
Old Oct 27, 2008 | 11:49 AM
HIGHOCTANE's Avatar
850 does it as well, I'm wiith snosnake, either that or the idle air control valve closing. I haven't investigated it as it didn't alarm me.
Old Oct 27, 2008 | 03:36 PM
SCRAMBLER500XXX's Avatar
the noise you are hearing is the idle air control motor resetting itself, nothing to worry about.
Old Oct 28, 2008 | 11:01 AM
wlvrn's Avatar
i never noticed that before. ill have to listen next time
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
