Jetting wiz needed
Old Nov 6, 2008 | 01:25 AM
deerwagon's Avatar
Default Jetting wiz needed
Sell it - buy an EFI, lol... sorry no help, just wanted that scary pic of the monster to be gone... Good Luck!
Old Nov 6, 2008 | 10:47 AM
firehog's Avatar
LMAO! I think I'm going to follow you around with a pic like that!!! Does she like scary clowns? LOL!
Old Nov 6, 2008 | 07:45 PM
gn386's Avatar
Okay I think we are on the right track. she was alittle hard to start since the carb was completely dry. But after alittle finese it started an ran pretty good. Took it up and down the streets alittle and got better after beating on it a couple of times. The few things I noticed 1. The header got real cherry hot (maybe normal but it was dark and I never noticed before) 2. Reved up quicker 3. when coming to a stop the idle seems to be alittle high and drops as it's idling (yes it actually idles now I think I am on the right track now. I am gonna return to the garage now and check the misterious needle. You are a lifesaver fire appreciate it very much. Check back later after I am done [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 6, 2008 | 08:20 PM
firehog's Avatar
Yeah, when you think you got it right make a wide open throttle run and shut it down from all out and then check your plug to make sure it is not white, which means you are too lean and need to increase your main jet. If it is black, which I doubt at 160, you are too fat and need to go down on the main jet.
Old Nov 6, 2008 | 08:36 PM
  #15
gn386's Avatar
Okay the needle is set at the third step from the top(the idiot must have done something right. Damn I knew that was coming have to remove the tank, ya think they would have thought this through alittle more. You are the man firehog going smooth so far I know thers a speed bump some where coming.
Old Nov 6, 2008 | 08:45 PM
  #16
firehog's Avatar
Ha, there always is. Removing the tank can be a pain. Make sure you pull the fuel hose down before reinstalling it so it doesn't get caught up and also make sure there is free play in the choke.
Old Nov 7, 2008 | 06:37 PM
  #17
gn386's Avatar
Yep she's still lean. I am trying to locate jets 170 175 &180. looks like you were right .
Old Nov 7, 2008 | 06:40 PM
  #18
firehog's Avatar
Try 175 right off the bat if you can locate it. Then you can go up or done if need be, but I think 175 will be right for you.
Old Nov 7, 2008 | 06:44 PM
  #19
gn386's Avatar
Well that's the trick noone local even stocks jets other then ones people have ordered the 4 pack @ $40 and I am not ready to spend that yet. I am gonna go one more local place
Old Nov 7, 2008 | 06:55 PM
  #20
firehog's Avatar
Ouch! The entire jet kit is only $50 from dynojet! Robbery! One of my local shops only charges like $5 for a jet and they keep plenty of them. Good luck!
