Upgrading
Old Nov 12, 2008 | 07:54 PM
  #21
polarisboy20's Avatar
Default Upgrading
ok so if i had to get a new polaris and i like power but it cant be expensive! and i ride at a place in tennessee! and its called windrock atv. it has over 75,000 acres of mud, hills, sink holes, gravel roads that are 25 miles long and look it up and windrockatv.com! it has to be the best place in the south.
rly need to check it out!
they have spring summer and fall jamboree's and they have rock climbing, drag racing, poker runs, and everything were goin up here in a few weeks and its gonna be crazy! weve got like 10 people goin with us!
Old Nov 12, 2008 | 08:06 PM
  #22
scrambler400enoge's Avatar
Shapeshifter Rider
Default Upgrading
To bad I'm in indiana.I'm actually in the next couple weeks gonna sell the scrambler and buy a banshee.It will be tough to see it go but I need more speed.
Old Nov 12, 2008 | 08:07 PM
  #23
Default Upgrading
ya umm ive got a problem with my radiator and the overheat light came on and it has a new antifreeze and im not sure whats wrong? can you help me?
Old Nov 12, 2008 | 08:11 PM
  #24
Shapeshifter Rider
Default Upgrading
Do you know where the resevoir tank is?i'll get a pic up in a little bit.
Old Nov 12, 2008 | 08:13 PM
  #25
Default Upgrading
i dont think?
Old Nov 12, 2008 | 08:26 PM
  #26
Shapeshifter Rider
Default Upgrading
You kno where you turn the gas on and off and that little thing off to the right with a cap on it thats the antifreeze resevoir.At the bottom of it there should be a hole with a hose check the hole fitting to see if it's cracked ran into the same issue on mine a while back.
Old Nov 12, 2008 | 08:29 PM
  #27
Default Upgrading
i looked and it looked fine just a little moist but not much at all!
Old Nov 12, 2008 | 08:34 PM
  #28
Shapeshifter Rider
Default Upgrading
check all hoses,and drain the resevoir and run it like that with only fluid in the radiator.If the heat light does'nt come on(ride it for a while)then we've found the problem,somewhere between the engine and resevoir.If it does come on then you need to get your radiator cleaned.
Old Nov 12, 2008 | 08:36 PM
  #29
Shapeshifter Rider
Default Upgrading
Also check fan for obstructions.
Old Nov 12, 2008 | 08:41 PM
  #30
Default Upgrading
ok and if you had to pick between a sportsman 800, a grizzly 700, king quad 700, and a brute 750 which would you get??????
