bendix issue
Old Nov 20, 2008 | 08:43 PM
marmon's Avatar
Default bendix issue
any more ideas?
Old Nov 20, 2008 | 11:19 PM
eggenz7's Avatar
are you sure you got the right bendix and it is engaging with the starter/flywheel.
just a thought but theres not really anything i can think of mechanically that could go wrong with a new bendix.
Old Nov 21, 2008 | 12:30 AM
marmon's Avatar
Ya it meshes great with starter, but it wont mesh in the flywheel when trying to start. It is the right gear though
Old Nov 21, 2008 | 12:32 AM
eggenz7's Avatar
when your holding the bendix does it freely spin one way and easily pushes out when you twist it the other way?
Old Nov 21, 2008 | 01:53 AM
  #15
mkgearhead's Avatar
When you had the starter apart, did you clean (lightly sand) the brushes and the surface the brushes ride on? If they're glazed over they won't make a good connection and the starter won't spin as fast as it should.
Old Nov 21, 2008 | 09:02 AM
  #16
MECHANIKE's Avatar
mk has a point marmon the brushes+ the commutator (the brushes contact this at end of starter) should be lightly sanded with 200 or more grit carefully+remove any sand,+shine the commutator just alittle by wrapping the paper around and turning.i've woke up many starters this way, the carbon tracking(blackness)does not conduct electricity well+has high resistance(slow turn).
Old Nov 21, 2008 | 09:23 AM
  #17
marmon's Avatar
Ya I polished them up with steel wool.(thats all i had) Maybe I'll try again with some emory cloth? Anybody know what voltage to look for or how to test the starter circuit for resistance?
Old Nov 21, 2008 | 09:35 AM
  #18
MECHANIKE's Avatar
if everything is shinny you don't have to repeat.....does your engine pull start easily?
Old Nov 25, 2008 | 10:17 AM
  #19
marmon's Avatar
pull starts just fine, except when it rips the cord out of your hand, thats why i hate using it.
Old Nov 27, 2008 | 02:49 PM
  #20
marmon's Avatar
well i think i fixed it. I ground a bigger lead on the gear with a zip cut and its worked 10 out of 10 times so far. Hopefully i didnt take the hardness out of the gear and it keeps working. Thanks for the help everyone
