Type of greece used on bearings
Old Dec 16, 2008 | 07:32 PM
michaelhembury's Avatar
Default Type of greece used on bearings
What type of greece should be used on the rear bearings of a 03 Sportsman 700?
Two other questions. What is a good notch to adjust the rear shocks to, factory set was the softest. Next question I pulled my outer rear bearings out with no problems, a little tricky keeping the bearings in place but succeeded. How do you get the inner ones out? Thank You Merry Christmas
Old Dec 16, 2008 | 07:54 PM
The race is not supposed to come out! Have heard of people greasing when this happens and sticking outer race back in,but bearing is sold as solid bearing (one big bearing with two inner and outer races! Best way to remove bearing is to remove hub,remove circlip,heat bearing and drive out bearing from one of the 3 notches inside hub.
Old Dec 16, 2008 | 08:02 PM
It all went back OK, I was probably lucky. I know it's after the fact now but I used standard Quaker State wheel bearing greece when I put it back together. What do you think?
Old Dec 16, 2008 | 08:19 PM
Give it a try,hopefully will do ok! If starts to make snap,crackle,pop noises,REPLACE! Good luck
Old Dec 17, 2008 | 09:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
keep an eye(ear) out as its not going to last. i used lithum grease to regrease them or a marine bearing grease w/ is better for repling water. imo.
Old Dec 17, 2008 | 09:56 AM
colt2245p's Avatar
i have always used a red synthetic grease from mobil.....it states its waterproof.....i always take the new bearings apart and clean the junk they use out and repack with the red stuff....it helps but i only averaged about 1200 miles on a set of bearings....
Johnny Mac
60
Dec 14, 2019 06:13 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Sassinm1
Sep 30, 2015 04:23 AM
jbrewster94
Sep 23, 2015 04:16 PM
