Changing a CV boot?
Old Feb 6, 2001 | 01:17 PM
Scramblin's Avatar
How involved and how long does it take to change a front CV boot on a 99 Scrambler? Just one more thing to add to my list of repairs for a machine that is worked on way more than it is riden.
Thanks,
Jason
Old Feb 6, 2001 | 01:38 PM
Thor's Avatar
How fast can you write a check for $60.00? LOL
There is a learning curve involved here. Your first one could take 2 1/2 hours or more.
But then again, somebody will write in and say that they changed theirs last weekend out in the whatever swamp right there on the trail in less than 1/2 hour.
Old Feb 6, 2001 | 02:01 PM
gregsims's Avatar
Unclamp what is left of the boot, disconnect ball joint and tie rod end... pull strut tower out, replace boot onto axel, reinsert axel into cv joint, reclamp boot, reattach tie rod and ***** joint. I have not tried this in a swamp, but it did take me an hour the first time. Now it takes around 30 minutes. Of course this assumes that your grease is not contaminated. Also I have done this on sportsmans and Grizzlys, never a Scrambler. Should be the same.
Greg
Old Feb 6, 2001 | 03:13 PM
Farmr123's Avatar
Don't forget that when you put the axle back into the CV joint that you push it all the way back together until it 'snaps' into place.
Old Feb 6, 2001 | 04:05 PM
Scramblin's Avatar
Thanks for the input! It doesn't sound to bad to do. What does a new boot run from Polaris? What clamps do you replace the old one with? Do you need a special tool for the clamps? and is the shaft splined and have to indexed correctly or is there only one way for it to go back together?
Thanks again for the help,
Jason
Old Feb 6, 2001 | 08:43 PM
gregsims's Avatar
You can buy the clamp pliars from any auto parts store or just use needle nose pliars. You can not put the axel in wrong. Oh, and the boot is $9.64.
Greg
Old Feb 8, 2001 | 10:17 PM
Todd Irvin's Avatar
I bought the special pliers....they don't work worth a ****...I use a small pair of ChannelLocks.
Old Mar 13, 2002 | 05:15 PM
SnowDrift's Avatar
Where do you guys find cv boots for $10?? I haven't found them for under $30.
SnowDrift
Old Mar 13, 2002 | 07:21 PM
MUDFUN's Avatar
I’d like to know where you found the boot for $10 also; I bought the kit from Polaris for around $30 came with clamps and grease. I got the ‘special’ pliers from the auto part store and found they were junk, finally got it 3 clamps later with needle nose pliers. Has anyone found a decent pair of pliers for the large clamp?
Old Mar 13, 2002 | 09:10 PM
500DUSE's Avatar
I got them for $20 at partsland.
and I bought a whole set(front back inner outer)
I'v been hearing about a boot with a life time guar,cost @$50
I tried useing the clamp pliers
but I thought a goodpair of 8 or 10" needlenose works great
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
bigbear350quad
Sep 11, 2015 12:40 PM
cornermike
Sep 10, 2015 08:30 AM
DM2015
Sep 7, 2015 10:36 AM
