shifting issue
Old Jan 1, 2009 | 10:30 PM
jerrymi's Avatar
Default shifting issue
I have a 04 polaris 700 efi i got used, my frist time out with it. I could not get it into highgear? low, rev neutral all worked great
Any help would be great
Old Jan 1, 2009 | 10:56 PM
user493's Avatar
Moto Psycho
Maybe the shifter linkage needs adjusting.
Old Jan 1, 2009 | 10:58 PM
jerrymi's Avatar
That is not it. I was shifting it at the transmission. Do you need to engage or disengage something first
Old Jan 1, 2009 | 11:38 PM
dslanec's Avatar
step on the rear footbrake THEN shift it- should go into gear. I had a 04 and that is how it went into high and park.
Old Jan 2, 2009 | 02:20 AM
RticKwad's Avatar
Runs Stealth!
How is your fluid level?
R'
Old Jan 2, 2009 | 10:17 AM
jerrymi's Avatar
That fine
Old Jan 2, 2009 | 10:46 AM
dslanec's Avatar
did you get it to shift? If not then the switch(not sure what it is) from the rear brake pedal on the floor board must need adjusting. They will not shift into high without stepping on the rear brake.
Old Jan 2, 2009 | 11:30 AM
JCDEYO25's Avatar
Yea on my '05 you have to push down the foot brake to get into high or park...
John
Old Jan 2, 2009 | 12:51 PM
Double D's Avatar
Jerry, are you able to get it into park? Mine is the same way, foot brake needs to be pushed for engaging into park and high.
Old Jan 2, 2009 | 06:49 PM
jerrymi's Avatar
Once again you guys figured it out, the foot brake was not connecked to the tranny (thing, that gets pulleddown when you step on the brake.
Works well now THANK YOU
