Water temp
Old Jan 5, 2009 | 05:49 PM
jerrymi's Avatar
Default Water temp
I have an 04 700 efi sportsman, does any one know what the temp the thermostat should on at ( i can not find anything in the owners manual.
The dealer could not tell me either, they said it was not in the records. They could order me one it would cost $50.
Has someone replaced theirs with a non dealer/polaris part if so what.
Old Jan 5, 2009 | 09:25 PM
TLC's Avatar
TLC
Default Water temp
You can read though THIS there many parts that can be substituted.
Old Jan 6, 2009 | 10:00 AM
SCRAMMYTODD's Avatar
Default Water temp
The engine should run around 190 degrees. I've put one in my Scrambler and one in my Sportsman and I used OEM parts.
Old Jan 6, 2009 | 10:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Water temp
the fan should kick on around 210 degrees and off again at 190 degrees. you buy a set up thru quadovator but its more then $50.
Old Jan 6, 2009 | 01:06 PM
tipo176's Avatar
Default Water temp
Try one like this.
Old Jan 6, 2009 | 05:33 PM
02magnum500's Avatar
Gets his share of deer.
Default Water temp
tipo176, what are the two arrows on the pod for? and the red toggle for?
Old Jan 6, 2009 | 06:28 PM
Spdecat's Avatar
Default Water temp
<div class="FTQUOTE"><begin quote>Originally posted by: 02magnum500
tipo176, what are the two arrows on the pod for? and the red toggle for?</end quote></div>
My guess maybe signal light's and the red one maybe hazard or horn .
Old Jan 7, 2009 | 08:23 AM
jerrymi's Avatar
Default Water temp
Tipo176 weredid you place the sender for thegauge
Old Jan 7, 2009 | 08:46 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default Water temp
Call Steve at cheap cycle parts.com and save a bundle on the part. They sell OEM Polaris parts MUCH cheaper than the dealer. Good knolegeable folks out of southern IN. 1-866-842-0086.
Old Jan 7, 2009 | 10:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Water temp
the gauge is where the choke would have gone. im guessing his bike is road legal and needs turn sig. and the rest. guesssing by looking at his sign/ he is from norway??
