Should you clean the Clutch on an ATV?
Old Jan 8, 2009 | 03:35 PM
Beau49's Avatar
Default Should you clean the Clutch on an ATV?
I guess I am full of questions today. Sould the Clutch be cleaned and if so what would be the best thing to use? Also should you lube the the moving parts of the clutch? What would you use to lube it?
Old Jan 8, 2009 | 10:25 PM
eggenz7's Avatar
no lube. with the clutches spinning as fast as they do it would spin the lubricant onto the faces of the clutch causing problems for a while. the only cleaning i have ever seen recommended is to take a really light grit emroy cloth and lightly sand the faces of the clutch to break up any glaze thats there. it will allow the clutch to grip the belt better.
Old Jan 8, 2009 | 10:31 PM
upnort's Avatar
I sometimes blow the belt dust out with an airhose too.
Old Jan 8, 2009 | 11:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
compressed air to blow out the belt dust and i use scotch bright pads to clean up weights, helixs, and clutch faces if need be.
Old Jan 9, 2009 | 12:50 AM
smilenbob1's Avatar
also check the clutch buttons and rollers for excess wear
and also its always good to inspect the belt.
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
