To pre-mix or not to pre-mix, that is the question.
Old Feb 8, 2001 | 08:48 PM
codeman's Avatar
I have had it recommended to me to switch to pre-mix when I do my porting and shave the head. Is this the same feeling shared by must people?
Old Feb 8, 2001 | 09:32 PM
CaptNemo's Avatar
Since you're going to add a lot of mods to the TB, and the jetting will be much richer than stock. The oil injection will have the same output amount and the amount of fuel passing through the engine will be much greater. This will throw the fuel / oil ratio off considerably.
Add some oil to the fuel and let the engine live longer.
Old Feb 9, 2001 | 10:34 AM
Jack's Avatar
There have been many failures due to the oil injection setup. pre-mix does nothing more than assure you that you are getting the proper ful-oil ratio. The higher modified you machine is, the more i would lean to pre mix.
SOLOLUCKY
Oct 4, 2024 09:09 PM
bigred20653
Oct 2, 2015 10:05 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
Rob4092
10
Mar 12, 2001 09:52 AM
