scrambler 500 4x4 problems
Old Feb 15, 2009 | 12:07 PM
spartafireman82's Avatar
Default scrambler 500 4x4 problems
i just bought a 2000 scrambler 500 4x4 i was told everything was fine til i rode it yesturday. when i was riding it i wasn't doing good in two wheel so i stopped put it in 4x4 and only three tires were turning then both kicked in then nothing both stopped. now i took it out 4x4 and i turn sharp and spin the tires one of the fronts kicks in. anybody out there have any ideas what could be wrong?
Old Feb 15, 2009 | 12:12 PM
ftwflh's Avatar
First welcome to the forum!
On your 4x4 problem try changing the hub fluid.It may take a few changes to get it to clean up.Next it is a good idea to invest in a service manual
Old Feb 16, 2009 | 01:13 AM
ok i took aparta my hubs to find out on one side i have a bearing that is tore apart inside of there. i cleaned everything up and have new wheel and strut bearings on the way just want to know how to take out the front drive shafts so i can get the old bearing and race out thanks
Old Feb 16, 2009 | 05:54 AM
ftwflh's Avatar
Knock out the roll pin on the differential u joint
Old Feb 17, 2009 | 01:41 PM
ok got the pins out took out the old races and bearings. from the looks of this machine i need to check it all over before i go anywhere with it. i want to change the oil in front dif but not sure how or what to use to fill back up
Old Feb 17, 2009 | 04:27 PM
ftwflh's Avatar
Use Polaris front dif fluid.Drain it underneath
Old Feb 17, 2009 | 08:30 PM
i'm really glad i found this website you have been very helpful. this is the first polaris i have owned my girlfriend owns a 03 trailblazer 250 but been a very good machine no problems but now i have one of course it's going to break on me. i have an 88 yam warrior nothing but problems for me everytime i ride i swear i have to fix it afterwards. but again thank you for all of the help where do i refill it at?
Old Feb 17, 2009 | 09:14 PM
ftwflh's Avatar
You can see the fill cap on the upper part of it
Old Feb 21, 2009 | 02:09 AM
ok i got it all put back together and well its a 3 wheel drive still. any ideas i switched the wires around and it still works the good side so i think i have power
Old Feb 21, 2009 | 07:02 AM
ftwflh's Avatar
Check or change the armature plate that is the main problem most the time.Be sure your gap is correct too.
