Rev Limiter UPDATE!!!!!!!!!
Old Feb 10, 2001 | 08:06 PM
MilleniumScr500's Avatar
Ok here we go this is for the Scramblers I did this today and everything works great
open up the front nose piece there you will find a rectangle rubber female spade connector there is 2 of them the one you want is the one with the grey wire with and orange stripe unplug that wire from the connector (REVERSE OVERRIDE IS NOW GONE)
Now to get it so the 4x4 works is a little more difficult but it is easy look at your reverse override button the wires you want are the grey wire with a white stripe and a red wire with a white stripe see where they come down in the nose piece take a little bit of the insulation off of each one now take a wire and splice it between both wires tape them up good TADA you now have 4x4 and no revlimiter when in reverse without having to push in the button VERY HANDY I think
Your reverse light and the AWD still work like normal too.
Well I posted about the Revlimiter ealier but I just got done doin the 4x4 part so I had to update ya all Hope this helps some of my fellow ATV'ers out..........If you have any ??? let me know I tried to explain it the best I could
Have a good one
Old Feb 10, 2001 | 10:44 PM
ScramblerDave's Avatar
I did this to my 2000 scrambler back in october and have had no problems with it. It's great not having to use that stupid override button.
Old Feb 10, 2001 | 11:38 PM
Yeah it is way better now.
The reason i did it was because once when i got stuck I could not go forward and had to go backwards but I had to get off my machine to get it out and it was so hard to work the throttle push that stupid button and push the machine it was a 2 man opertion but i did manage to get it out by myself. But know things should be lot's better if it ever happens again.
Have a good one
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
chewy78
Sep 8, 2015 10:37 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
