Boiling Gas
Old Jul 2, 2009 | 07:48 PM
albertaborn's Avatar
it sound like if its building up pressure there is a venting issue prob a plugged hose the pressure changes the properties of the fuel making it volitile to boiling
Old Jul 2, 2009 | 08:15 PM
bassballs818's Avatar
if you not venting properly its definently gonna bottle up heat. The same happens to a gas can when the sun hits for a while. Maybe try blowing the gas cap out with an air hose to get rid of gunk or something that might be in there.
Old Jul 3, 2009 | 11:48 AM
helmethair78's Avatar
I had the same problem on my popo. The deal is that riding in hot temps at low speeds the gas tank gets too hot from the radiant heat off the engine and exhaust.
To fix this, I removed the factory heat tape off of the gas tank and cleaned it very well. I then installed some stick on heat shield on the bottom and sides of the tank. I covered a much larger area than the factory did. I covered as much of the tank as possible without removing the front plastic.
This seems to have fixed the problem.
Design Engineering DEI 010462 - DEI Reflect-A-Cool Heat Shields – SummitRacing.com
PrairieDog126
Sep 12, 2015 06:53 PM
400H0
10
Aug 20, 2015 07:34 PM
ghost civic
Jul 27, 2015 03:15 AM
Grizzyowner
May 19, 2003 12:30 AM
DanimalFL
Dec 4, 2001 10:56 AM
