2008 Sportsman steering stem seams loose?
Just came home with my new (used) 2008 Sportsman 800. The quad is mint and does not have a scratch on it. Miles are 147. Only thing I have noticed is that the steering stem is loose & has some wiggle feel to it. Warranty is up. What should I be looking for to repair it.
Thanks,
Thor
Thanks,
Thor
my 00' sp 335 did that. theres a nut at the end of the shaft behind the radiator with a pin. remove the pin. tighten the nut. not to tight tho. just tight enought so it dont move. not shure the size tho. i cant rember.
1 7517428 Bolt 4 Usage
2 5246732 Bracket, Upper, Bushing 1 Usage
3 5433866 Bushing, Upper 2 Usage
4 1822630-067 Post, Steering, Black 1 Usage
5 7556162 Bushing 2 Usage
6 5222393 Flangette 1 Usage
7 3514352 Bearing 1 Usage
8 7547158 Nut, Slotted, Hex 1 Usage
9 7661633 Pin, Cotter 1 Usage
10 7542343 Nut, Flange 4 Usage
my 09 xp 850 with 1 mile has a little play also when sitting on the seat and pulling up on the bars it moves alittle i think it is normal my last 05 sp500 also did the same thing
