HELP MY 500EFI WONT START!!!!!!!!!!!!
yep cranks good, battery is strong, everything lights up and it pops every once and a while. I have also checked the crank sensor and made sure the flywheel key wasnt sheered off !!!!
<div class="FTQUOTE"><begin quote>Originally posted by: bigfatguy2
yep cranks good, battery is strong, everything lights up and it pops every once and a while. I have also checked the crank sensor and made sure the flywheel key wasnt sheered off !!!!</end quote></div>
Crank sensor what does that do ? Does my 08 carb machine need one ? I think NOT .
Pull your air filter out. You have sucked a piece down the intake, blocking air, get a good flashlight and look real good. It may be past the butterfly.
A fellow on Nyroc had that happen to him. Also, check rear braklight switch and start in gear override.
#16
Have you checked your fuel flow rate?. You have pressure but what about fuel flow?. I would drain the fuel line then see if the pump sends fuel through the line. What about debris in the tank, from what I understand, the pump is in the fuel tank, is the tank clean?.
#19
I'm in Eagle River which is 3 hours from you.A friend has the exact same quad as yours and I thought we could swap parts until we get it running so I guess it's your call.
