Oil in Air Box?
Old Mar 17, 2009 | 08:52 PM
Cutfoot's Avatar
Default Oil in Air Box?
It is easy to overfill the oil on a pred. Important to let it warm up for awhile before checking the level. I try to keep my level near the low end especially if I plan on riding track with alot of jumps. Check the level cold then run it for about 15 min, check it again, you will see the difference.
Old Mar 17, 2009 | 09:45 PM
lasher10's Avatar
you put too much oil in the case........
Old Mar 18, 2009 | 04:30 AM
knezz's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Cutfoot
It is easy to overfill the oil on a pred. Important to let it warm up for awhile before checking the level. I try to keep my level near the low end especially if I plan on riding track with alot of jumps. Check the level cold then run it for about 15 min, check it again, you will see the difference.</end quote></div>
Hmmm???? Check the oil after it has been running for 15min??? I'm new to the game but as I checked the oil I was thinking cars - check oil only after it has been sitting as all the oil need to settle to get a good reading. Is that not the case with the Predator or other ATVs?
