lock & ride windshield issues
i got a lock and ride windshield on ebay. seemed to be a good buy. tell i put it on. its either me, or somethin is missing.
i got the windshield on. and after 10min trying to get the clips round the handelbars and wires. i got it to clip. 15sec my butt!!! but it dont stay clipped. but on the top and bottom of the clip there is a small hole. is there supose to be somethin there? anyone have pics of there bracket/clips on the bars??? or an instruction manuel for theres you can show me? either that or im thinkin about reselling it.
I installed a LockNRide windshield on My 400 sptmn.and it worked out just fine.It was a bit of a bear to get it clipped on but I have had no issues with it coming unlatched.I do`nt think mine had any holes for retainer pins but there is stubs that the latches snap over that keeps them from coming unlatched.
I`ll take a couple of pics of the latches and post em for You in the morning.
If You ca`nt return the windshield or got such a good deal You do`nt want to then maby the latches can be drilled and a small retainer pin or bolt put through them.I think the latches on Mine were aluminum so drilling would`nt be an issue,an issue might be if there is not enough room to drill them without destroynig them.
i wish i would have took a closer pic of the latches. but where the stubs i think are supose to be are gone. so drilling woldnt help. since theres noting to drill into. and my clips and pretty much everything is plastic cept the hinge pins and the threaded bolt....
Here`s a pic of the right side latch on Mine,Frost and all.LOL
If the guy wo`nt take it back then I think it would be feasible to drill a hole through the latch assembly and install a 1/8" or a 3/16ths" pin or screw through it to keep it secured.
You can see the nub sticking through the hole.
