New Modification List
Old Feb 13, 2001 | 11:10 PM
CaptNemo's Avatar
I've gotten a couple of E-Mails asking about modifications to the Scrambler, so here goes:
RCR Air Box Modifications
K&N Air Filter w/ Outerware
HPD 39PWK Carb & Single Throttle Cable
V-Force Delta II Reed Cage
HPD Reed Cage Spacer
RCR Porting
RCR Cylinder Head Modified for 92 Octane Gasoline
Wiseco Piston 0.040" Oversize
HPD Pipe & Stock Silencer / Spark Arrestor
Owner Fabricated Oil Block Off Plate
32:1 Pre-Mixed Polaris Synthetic Gold Oil
Oil Tank Removed
HPD Clutch Kit
Owner Fabricated Aluminum Dash Panel
Owner Fabricated Aluminum Oil Tank Cap Block Off
Renthal 250R Bend Handlebars & Diamond Grips
HPD Lower Steering Bushing
Polaris Rear Rack
Warning Decals Removed
Future Modifications In no Particular Order:
Jet-Hot Coated Exhaust System
Works Performance Front Strut Cartridges
Aaen Roller Clutch
Aluminum Rims and New Tires (either Holeshots or Bandits)
Old Feb 14, 2001 | 08:52 AM
00TB250's Avatar
Got any pictures of that beast Capt?
Old Feb 14, 2001 | 07:59 PM
Xplor's Avatar
I never thought that I would be "one of those guys" with a page long list of mods...but now I am! Thanks to alot of influence from these forums!
Brian
Old Feb 14, 2001 | 08:39 PM
A400L's Avatar
Just for kicks,
1999 POLARIS SPORT 400L
ENGINE: 378cc liquid cooled 2-Stroke
BORE & STROKE: 83mm X 70mm
CRANKING COMPRESSION: 180lbs
PISTON: Wiseco Pro-Lite
PORTING: Rick Ritter (RCR), matched to HPD Race specs
HEAD: HPD billet head, 14:1 compression w/girdle kit
SPARK PLUG: NGK B8EV
CARBURETOR: Kehin 39PWK
RAD VALVE: Delta V-Force w/ carbon fiber reeds
AIR FILTER: K&N Filtercharger (no air box)
EXHAUST: HPD Trail, nickel finnish
SILENCER: RCR stainless steel
FUEL: Phillips ‘66 110 OCT.
OIL: Maxima 927 @ 40:1
OIL INJECTION: Pre-Mix, HPD oil injection elimination kit
FLYWHEEL: Shaved 11oz. By RCR
WHEELS: Douglas .190 aluminum Red labels
TIRES: ITP Holeshot XC's F/R: (Skat-Trak Haulers on .190's for sand)
HANDLEBARS: Renthal aluminum (Banshee)
GRIPS: Scott Hurricane
FRONT BUMPER: DG Alloy series
A-ARM GUARDS: DG Baja series
THROTTLE COVER: HPD aluminum
GEARING: Sunstar sprockets; 14/34
TACHOMETER/E.T. GAUGE: Westach
BRAKES: HPD Split kit w/dual MAGURA cylinders/levers (removed foot pedal)
Custom made Goodrich steel braided lines, EBC "SV" pads/rotors
CLUTCHING: HPD Red Yellow primary, HPD Lavender Secondary in #2 hole
AAEN Roller Action with 42/38 Helix; engagement set @4200RPM's
FLYWEIGHTS: TPI adjustable
DRIVE BELT: Goodyear Powerstreak
SUSPENSION: Mcpherson struts, rear FOX shock; w/ Red Shockwares
AAEN steering damper, HPD bronze steering and A-arm bushings
SWINGARM: Hot Seat +3", powdercoated RED
Plans for '01:
Hot Seat chromolly A-arms and steering stem
FTZ 38TMX alky carb
Old Feb 14, 2001 | 09:29 PM
NewDSLover's Avatar
ME TOO !!!!!!
2000 Scrambler 2x4
Wisco 20 over piston
VForce Delta Reeds
Reed Spacer
Clutch Kit
HPD Pipe
Stock Muffler(quite)
Porting(did myself)
Dirt Devils(rear)
Stock Oil injection(more weight, but better!)
(the stocker varies the oil from 200:1 - 16:1)
This saves plugs and parts at high revs. Only remove injector if you race or like to mix.
My sled has no trouble with K&N/Piped ex's in a drag. Let's hear your stories!
Old Feb 14, 2001 | 09:50 PM
Xplor's Avatar
O.K. Let me jump on the bandwagon!
HPD Trail Pipe
JetHot Coating
HPD Agressive Clutch Kit
HPD Trail Porting
HotSeat 12:1 Billet Cool Head
Aaen Roller Clutch
39mm Kehein Carb
Custom Airbox mod + Uni
V-ForceII Reed valves + spacer
Weisco Piston
Lightened Flywheel (15oz)
FMF Turbine Core II Spark Arrestor
HPD Adjustable steering dampener
EPI Tie Rod Ends
Custom splash guard for PVT exaust
HotSeat DualRate Springs (front)
Custom Triple Rate (rear)
Works steeler struts (front)
Shockwears (red)
22" Bearclaws (rear)
23" Razrs (front)
Renthal Aluminum Handle Bars (400ex bend)
Scott Grips
MSR Brush/Hand guards (red)
CV Boot Protectors from Sportsman
10' Flag for future duning
Chain guard mod (-2 lbs)
Speedometer
Custom "Shadow Slayer" Shift Lever
Polished Aluminum stock front bumper and rad guard
Floorboards removed
Banshee DG Nerfs + footpegs
Soon to come:
Durablue wheel spacers
20" Razrs on 9" ITP Aluminum (rear)
21" Razrs on 10" ITP Aluminum (front)
HotSeat Aluminum front bumper
Oil Injection elimination
Custom Seat cover
Things already taken off:
Front and rear racks
Gas can rack
Polaris hand guards
Mud flaps all-around
EPI Clutch Kit
Must have forgotten something...
Old Feb 14, 2001 | 09:57 PM
CaptNemo's Avatar
It looks like a stocker, except for the dash, the block off on the front hood, the rear rack and the missing warning decals.
This thing's a "sleeper", it looks bone stock, but runs like a guided missle.
That's the fun, blowing someone into the weeds with a stock looking quad.
I've been looking at the photos of some of the other guys 400's,( Jerry, Mike, Jack, Quadfather, etc. and all the others I forgot to mention ) with floorboards and mud flaps removed, modified PVT intakes, etc. and they're giving me ideas, but we'll wait and see.
Old Feb 15, 2001 | 01:31 PM
adamnieman's Avatar
Xplor,
How does that FMF Turbine Core muffler sound? I am considering buying one to go on a RCR Stage 1 kit. I hope it is not too much louder then stock, but I bet it flows much better and weights less too. Thanks.
Old Feb 15, 2001 | 06:58 PM
Xplor's Avatar
It is beautiful, shiny and weighs in at about half of the stock one. So far, sound wise, she is running at about 0.00 decibles...No, seriously though, I am still waiting on my cylinder and carb from HPD so I have not tried it yet. It shouldn't be that much louder since it is forestry approved. I will let you know though.
Brian
shimanok2
Jan 29, 2016 07:37 PM
Sep 23, 2015 06:23 AM
Alex G.
Sep 16, 2015 12:13 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Lou Domenech
Sep 11, 2015 06:35 PM
