2000 Scrambler 500 4x4 not engaging?
Old Apr 17, 2009 | 09:20 AM
hondafl350's Avatar
Question 2000 Scrambler 500 4x4 not engaging?
Hi I have a 2000 Polaris 500 scrambler 4x4 and this is my other problem. The hubs will not engage. I have had them apart a bought 10 times and everything looks good in regarding to the manual. I just can’t find out what the Holmes of the magnet coils should be in my manual? Is it possible that the rings that grab on the magnets are holding residual magnetism? And not grabbing as strongly as they need to? I am as a loss with this one I think.
Old Apr 18, 2009 | 05:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you have power going to the hubs and the arm. plates?
Old Apr 18, 2009 | 08:39 AM
TLC's Avatar
TLC
Is your scrambler equipped with a speedometer? If the speedo knocks out you lose AWD.
Old Apr 18, 2009 | 08:46 AM
hondafl350's Avatar
Unhappy
I don’t believe this scrambler has a speedometer. How would I tell if it was supposed to have one? I am getting voltage at the coils and the little plates that stick to the magnets are grabbing. But it still is not engaging. Everything looks to be moving freely.
Old Apr 18, 2009 | 08:52 AM
TLC's Avatar
TLC
I think only the Canadian models came with speedos. When you tighten the castle nut,you can not go beyond 12ft/lbs torque. Did you use correct type and amount of hub fluid?
Old Apr 18, 2009 | 12:33 PM
hondafl350's Avatar
Unhappy
I didn’t tighten them that tight I just put them tight by hand. I am using the proper hub oil and I’m fining them to 4 o clock. I will try to tighten them up to 12 foot pound and see it that helps.
Old Apr 18, 2009 | 01:00 PM
TLC's Avatar
TLC
Manuals says ,to the last castle nut notch ,but "can not exceed" 144in-lb.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
1000gade
Sep 9, 2015 03:35 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Myronh
Sep 8, 2015 11:27 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
