2004 Sportsmen 700 efi
Im having some issues with my sportsmen it seems that when the awd switch is off it still engages for wheel drive when the rear tires are spining is this normal? also i have fuel leakin off the block of the motor looks to be coming off an injector are thoughs hard to get to to replace?
Thanks
Gib
Thanks
Gib
I had it in to the dealer when it was on warrunty and they replaced a ring in side the front diff. I dunno what though I think its the same problem as then. I think its a ring for sure around an injector.
okay im going to take it all apart and look at it is it an expensive part or not i think the guy told me it would cost 575.00 to fix it the first time but that was on warrenty and included the labor
the roller cage is an expensive part. if you get it apart and find its the roller cage, then the guys here can give a john deere pn# for a less expensive replacement to fix it.
I paid $113 with tax for a cage, rollers, a-plate, and seals from John Deere. Let me know if you need the part# and I will look them up.
The cage kit is john deere part number-MIA10667. The cage also comes with the updated armature plate. If you also need rollers due to corrosion the part number for those is MIA10666. I recently changed mine and the parts work excellent. I paid 110 dollars total for the parts and fluid from john deere.
Sw00p
Sep 24, 2015 02:50 PM
