850XP or 550XP?
Old May 20, 2009 | 06:51 PM
BlueManQuad's Avatar
I've never ridden at anywhere near that altitude, but I think therein lies the answer to your question. Since both the 550 and the 850 will lose power at that altitude I would think you would want all the power you could get to begin with so that you will still have plenty after what you will lose for altitude.
Old May 21, 2009 | 07:17 AM
bigt2317's Avatar
I have a 550 and the sole reason I didn't pick up the 850 was for their extra fuel consumption. When I go on long rides (4-8 hrs), I don't have to stop riding to fuel up with my old sportsman 500. I could get over 115 miles out of my '96 500 so I'm hoping to get at least that with this 550. I've heard of a few 850 owners get 1/2 that out of a tank but since their are so many variables I'm not sure how apples to apples that would be. I ride pretty hard, I ride fast, I do like to do stupid crap and the 550 is plenty for me, for now. lol
Old May 21, 2009 | 03:52 PM
DCT's Avatar
DCT
Banned
Originally Posted by Dublin
Hiya Folks,
I think I'm in the market for one of the new Polaris XP's. Without a doubt, I'd like to get the 850 version but I'm not sure I want to spend the extra cash for it vs. the 550. I plan to use this primarily for plowing snow and trail riding at altitude (approx. 8600' - 12000'). No hunting or heavy hauling etc... Can any of you that perhaps own each of these or perhaps have driven both give any insight into whether I will forever kick myself for not getting the 850? Or perhaps, the reasons to get the 550 instead (aside from costs)?
Thanks much,
cc
I agree with the other guys... if you are going to be plowing a considerable amount of snow... get the 850. It will also come in handy at those altitudes.
Good luck.
Old May 21, 2009 | 04:55 PM
TLC's Avatar
TLC
You have to plow slow while in low range so how would a 850 have a advantage over the 550? There both are going to over rev in low range after 20 mph even a 350 in low range would.
The only advantage a ATV has over another for plowing is the heavier the better and traction due to its tires or use of chains or a true AWD system of some type.
Old May 21, 2009 | 06:29 PM
  #15
Dublin's Avatar
Maybe you could have your wife talk to my wife?
Thanks folks for all the advice. I'm still a bit on the fence but one thing's for sure, I need to find a dealer locally that isn't exhorbitant on their pricing. I see dealers in other states offering much better deals but alas, they are not able to ship per their agreement with Polaris. I'll look around Colo, AZ, Tx, and maybe OK for the best deal I can find. Depending on what I find, that may determine what I get. Thanks again for all the insight.
Cheers,
cc
Old May 21, 2009 | 08:47 PM
  #16
DCT's Avatar
DCT
Banned
It's called torque.
Now tell me you think that both engines have the same amount of torque at 3500-4000 RPM's. Then tell me that you don't think an engine with more torque can push more... with everything else being equal.
Old May 21, 2009 | 10:38 PM
  #17
switzomatic's Avatar
Default 850 or 550
There's no replacement for displacement!
Old May 21, 2009 | 10:45 PM
  #18
MEGA XP's Avatar
You got that right. I use 2 500 rubicons and the 550 for commercial snow removal. I have yet to run out of power before running out of traction. In all my uses I have never found an instance that I needed more power. Plus, when I move snow they run for more than eight hours, so fuel consumption is a bigger issue for me. My 550 XP plows more snow than my buddies 700 Griz!
Old May 21, 2009 | 10:53 PM
  #19
MEGA XP's Avatar
Originally Posted by DCT
It's called torque.
In snow plowing traction is the limiting factor. I've never run out of power before blowing the tires off while plowing snow. In fact the My XP out does a Grizz 700 same blade size and the XP takes the pile about 17 Feet further with the blade straight pushing side by side.
Old May 22, 2009 | 05:38 AM
  #20
TLC's Avatar
TLC
That because a the Polaris weighs 100 lbs more than a Grizzly and its hard to keep the Grizzly in diff lock 100% of the time while plowing.
My old 350 Big Bear would snap a axle before it would ever run out of wheel turning power in 1st while in low range. If I put chains on its tires and added 300lb of sad bags on its racks It would out pull my 500.
