08 800 EFI HO Questions
Hey guys- I have an 08 800 EFI HO that I bought brand new. Lately, it seems like the machine is kinda doggy. The other thing I noticed yesterday while pulling a trailer in low was that around 3,000 rpm's it seemed like it was misfiring a bit. I'm going out trail riding tomorrow, so I'm hoping I dont run into any issues. Also, it seems like when the machine is cold it is a lot snappier than when it is warmed up.
The other issue I keep having is that the stupid heat shield rattles and is VERY annoying. I keep bending it and it will fix it for like an hour... Any suggestions on that?
Thanks in advance!
Jeff
Thanks in advance!
Jeff
x2 on the plugs, replace with NGK's. Also check your air filter, if you haven't changed it, might be time. Changing the clutch side plug is a PITA. I removed the clamp on the CVT intake, pushed the intake out of the way. Then I could just barely get a plug socket on the plug and used a small (6 inch) cresent wrench to loosen and tighten the plug. Make sure the kids are in the house..you will drop some "F" bombs...lol
Good to hear. What tires are you running and what size? I need some rear tires and was thinking about the big horn 2.0-- 26x 11x 12
Get some new bolts/lockwashers for your heatshields if you cannot tighten them enough to stop the rattling. I had a set once that bent(and kept warping after bending back) and would rattle on the pipe so I got longer bolts and added a few washers to get it off the pipe.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
