Gas ?
Old Jul 6, 2009 | 11:01 PM
rob883's Avatar
Default Gas ?
what octane do you run ? this is an 800 cc EFI model
Old Jul 6, 2009 | 11:22 PM
toolman4's Avatar
Unless you have modifications done, like a race pipe, you don't need to run any higher than the minimum in the owners manual. Higher octane does not mean more power.
Old Jul 7, 2009 | 06:08 AM
switzomatic's Avatar
Default Gas
Made to run on 87 octane. I run the non-oxygenated gas in mine which is only available in 91 octane here in MN which sucks(more $). I also use fuel stabilizer(always) and run some sea foam occasionally to keep the system clean.
Old Jul 7, 2009 | 10:21 AM
Rcher's Avatar
The manual recommends 87 octane. I never run anything less.
Old Jul 7, 2009 | 10:33 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I also use regular and run stabilizer. Unless you burn a tank per week, you should use fuel stabilizer.
Old Jul 7, 2009 | 08:38 PM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Rcher my friend, it would send you to the moon to really know that you are not actually getting a "true" 87 Octane when you fill at the pump. Many tests have been done, and 87 Octane is lucky to tip the scales at 85 when an additive is removed from the equation, and believe me, sitting in a large tank underground offers many opportunities for the Gas to separate.
