fault codes on a 06 sportsman 700
Old Jul 19, 2009 | 05:45 PM
05 hunting's Avatar
Default fault codes on a 06 sportsman 700
ive got a friend of mine that has a code 41 and 46 on his sportsman and im wondering if anyone has any idea what the codes stand for and also im wondering if any one has any idea were i can by a scanner to due diagnostics on the polaris products. thank you hunting 05
Old Jul 19, 2009 | 08:01 PM
JCDEYO25's Avatar
Took this info from my 05 service manual...
41.....Air temp sensor: open or short circuit to sensor voltage (ECU) or short circuit to ground
46..... Barometric pressure sensor: circuit high imput
John
Old Jul 20, 2009 | 07:46 AM
X2's Avatar
X2
Default TBAP Sensor, Codes 41, 45, 46
Had my 08 700 X2 in four times to the dealer, 3 times for broken wires on the TBAP sensor & R&R the sensor 1 time. (old sensor was ok)
Dealer has shown me the the connector and the wires ARE small gauge, but he also is blaming the mfg. of the connector. Polaris does need to come up with a better connector!
Now here is something else, I have 2 08 700 X2's and the other one has no problem.
Old Jul 20, 2009 | 06:05 PM
PolarisPile's Avatar
Yeah...My 04.5 has had the same problem I have repaired mine too...I found what looks like a pretty good solution on ebay under the polaris parts electrical section for 35 bucks. It's an aftermarket wiring harness that lengthens up the harness and has a new wiring with a new connector..It's all water tight. and looks like its pretty good. The item number is 150359590605 I don't know if I want to buy it or wait till mine breaks again. I don't know if this is a one off or if the guy has more of them.
COFatboy
May 2, 2020 12:06 AM
tombrown14
Nov 10, 2015 06:48 AM
tombrown14
Aug 26, 2015 07:30 AM
tropicalnuts
Aug 22, 2015 01:15 PM
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
